Simple use cases
This page contains some simple use cases that will help you apply TrendMiner in your day-to-day work. These use cases consist of a minimal number of steps, are easy to replicate and can be applied to a wide range of processes.
Views and layers
1. Comparing today's process behavior to last week's
1 minute
2. Check recent process behavior
1.5 minutes
3. Get easy access to frequently used tag sets
2 minutes
2_-_Visually_compare_process_behavior.png 3_-_Visualize_recent_process_behavior.png 4_-_Load_frequently_used_tags.png
Tag Builder
4. Smoothing noisy signals
1.5 minutes
5. Calculating a derivative
1 minute
6. Calculating daily production
2 minutes
6_-_Smoothing_noisy_signals.png 7_-_Calculating_a_derivative.png 8_-_Calculating_daily_production.png
TrendMiner Searches
7. How often did this behavior occur?
2 minutes
8. Report on monthly averages
4 minutes
9. Filter out unstable behavior
2 minutes
10_-_Discover_frequency_of_an_event.png 11_-_Reporting_on_monthly_averages.png 12_-_Filtering.png
Monitoring
10. Monitor on process thresholds
1.5 minutes
11. Monitor on similar process behavior
1.5 minutes
12. Set up a monitoring dashboard
1.5 minutes
14_-_Monitor_on_process_thresholds.png 15_-_Monitor_on_similar_process_behavior.png 16_-_Monitoring_dashboard.png
Rate TrendMiner
