Getting started [5/5] - Setting up monitors
If you've gone through the previous steps of this onboarding flow, you've now mastered tags and searches. Now, we will focus on how to use monitors to be informed (either in-app or via email) when specified behaviors are observed.
Our mantra is: everything you search for, can also be monitored. Learn how to be alerted either directly within the TrendMiner platform or via email when the specified search conditions are triggered in the video and discover more on monitors underneath...
Doing more with monitors
Utilizing automatic annotations, fingerprints, monitor tiles
When monitored behavior is detected, it is possible to have TrendMiner automatically annotate on top of the data.  Learn more
In TrendMiner, you can utilize fingerprint deviation monitoring. By applying this monitor feature you will be alerted when the current proces trend deviates from a selected fingerprint. Common examples include monitoring batch runs that deviate from golden batch behavior or process transitions that do not match a reference behavior. Learn more
Monitoring/alert tiles in DashHub enable you to check visually the state of your TrendHub monitors based on the trigger criteria you set. When a monitor alert is triggered, the resumption of a "Normal status" will see the trigger reset. Learn more
Simple Use Cases
Put your TrendMiner knowledge to practice!
10. Monitor on process thresholds
1.5 minutes
11. Monitor on similar process behavior
1.5 minutes
12. Set up a monitoring dashboard
1.5 minutes
14_-_Monitor_on_process_thresholds.png 15_-_Monitor_on_similar_process_behavior.png 16_-_Monitoring_dashboard.png
Get Quick Help
Need some more support? Check the Help menu in the TrendMiner top bar to get access to our support resources. Browse through the documentation in our Help Center, explore the Getting started guides or click 'Chat with us' to get direct help from a TrendMiner expert!
Enjoying TrendMiner? Share your experience to help the community.
Rate TrendMiner
